- Joined
- 17 Nov 2005
- Messages
- 20
- Reaction score
- 0
- Country
Chaps
any help appreciated as the MRS is giving it to me in the neck about our useless boiler again.
Boiler is a Gloworm 30SXI
2-3 years old,
heating system is fully zoned with heat stats for each room with pipes dropped form a central heating loop that runs through teh loft (I'm in a bungalow)
system is fully mains pressure
hot water is using a megaflow if that makes any odds.
Recently the boiler conks out at random intervals either with and F4 error (Failure during running) or F1 ignition failed.
British gas reckon it's either the gas valve or the ignitor. Theyv'e replaced the ignitor last week and it appeared to cure it however as of yesterday the problem is back.
I'm awaiting an engineer but my confidence in them is not high.
I noticed and pointed out last week that the spyhole into the combustion chamber was covered on the outside with a crusty substance. On scratching this off it appeared to be on the other side of the glass as well.
Any ideas?
Possibly related possibly not is that the water pressure has now started dropping rapidly needing filling up very often, all pipes are in the loft and I can't detect a leak. I noticed a comment that elsewhere on the forum that water could be finding it's way into the combustion chamber? does that make any sense could they be related?
thanks in advance I'd appreciate any suggestions.
2-3 years old,
Any ideas?
