Help - my guttering is rattling in wind !!
11 May 2004
The guttering above my house is making a loud rattling noise when th ewind is blowing. I haven't been up to check ( no good with heights ) but would like to get it fixed. From ground level I cannot see the guttering moving but it must be because of the type of noise coming from there. What is is the likely cause of this ? Could it be that the gutter brackets need replacing ?
Any advice would be greatly appreciated.
Sound like the bracket is broken where it clip over the gutter which you won't be able to see from below, so the gutter is lifting slightly in the high wind. You won't know until you get up there.
You should have a gutter bracket at least every 1 metre.
