Hi
This is my first post on the site so please bare with me . My problem is that my Hydramax power shower is continually dripping from the head when its in the cradle on the wall, it seems like the pipe from the head is storing water which is causing a pressure build up therefore creating the drips. The shower was brand new when installed and the house was a new build my other ensuite shower is exactly the same but no problems have occurred, Yet .
I am not sure if my next problem is in connection with the above but we have noticed a leak coming through to the lounge ceiling below. We have removed the shower cubicle skirts and discovered a wet and damp area so this problem must have started a while ago by the looks of things. The drain part of the under pipes are fine and we can not see any obvious splits. Any help would be greatly received. Do I need a new shower? Do I need to pull the wall to bits to replace the piping....I Hope Not ? Helpppppppppp
