moved to new council house 3 months, have been having serrious issues with high volume of really cold air circulating around, which is wiping out any heat provided off rads.
1. on inspection it appears doubling glazing units were simply thrown in few years ago, on removing pc trim around inside of windows there was gaps and at time of fitting no foam and or insulation was fitted around where the windows were fitted into the opening, council came out removed every trim on window and foam sprayed the gaps, and replaced trims, this i belive has made no difference waht so ever and the cold air is still present.
2. we have air vents in every bedrrom, letting in a high amount of cold air, these are due to be blocked off next week.
if the when the air bricks are sealed and the cold air is still present it looks like im going to have to get building contol out to produce a report on to what is allowing this cold air into the house.
this house is so cold its unbelivable and we aint even had a bad winter yet, the house is cavity insulated and last week we had loft toped up to current insulation depths.
i belive that the main problem is the double glazing units they will be approx 7 years old, and do not belive they were fitted currectly, the outsides have not been sealed, as i say they have foam filled the insides, the council admit that this should of been done when they were fitted but cant explain why they were simply thorwn in, and plastic trim used to hide the gaps on this inside with no insulation fitted before the trims were put back on, the cold air around the windows is unaceptable, all the windows shut and no gaps (paper test) are present.
any idears why this house is so cold?
