hi my mother is trying to find an air flow sensor (Potterton Lynx 300303) as hers has broken and she will have to buy a new boiler if she can't find one. Can anyone help? Thanks
I try to keep one or two s/h ones (somewhere!). They are getting harder to come by as there aren't many Lynxes being scrapped any more. Finding them on demand takes time and effort though - try boiler-mending/changing companies.
Is she CORGI registered to test and replace this part safely?
If not then how can she be sure that it really has failed?
The most common fault is a lead problem rather than the sensor itself!
Its actually based on a cooker pilot light ignitor. Gas came up through the hole in the middle and a 1.5v battery heated the coil to light the flame which was close to the main burner and lit that. Does anyone remember that cooker?
