Help needed, Hotpoint HDW60 Fault
3 Oct 2015
I had a problem where the dishwasher alarm went off and the 4th light started flashing on my Hotpoint FDW60 dishwasher, troubleshooter said that it was the water fill valve. I changed this and all seemed to go well for about 5 mins until the same happened again. I have checked the flow into the machine and that is good, does anyone have any more ideas???
Cheers in advance.
Yes. Put your post in the correct forum.
IMHO dishwashers have an inherent design fault. Specifically the cabling that trundles its way from the door to the gubbins inside. This gets bent frequently as you open and close the door and we've had to replace/repair wiring a few times over the years from different machines which has worn out/shorted.
