Help,
I am fitting a picture rail in my living room and all was well with the 45 degree mitre joints, however, I then came to a wall whose overall angle to each other was 110 degrees I thought no problem two 55 degree mitres will go the trick.............. ooooops wasted picture rail.
How do you cut mitres for non standard 90 degree corners? I also have one corner that is less than 90 degrees
Is it possible to do this with a macallister compound mitre saw?
Andy
Andy
