I need to remove rust from under the sills, including rusted seams, and to re-coat them in the best way to protect them against future chips and rust. I am not too bothered about the cosmetics - after all, I don’t intend to spend many hours on my back admiring the underside of my car!
The existing paint is lacquer-coated metallic finish. There are quite a few areas which I repaired last year with standard primer and metallic paint, but this has not lasted well. Also, some seams underneath the car are starting to rust badly. What I now intend to do is:
(i) Wire-brush all rusted areas down to bare metal.
(ii) Treat the exposed areas with a product that makes the rust remaining in pitted areas inert.
(iii) Treat the rusted seams with a similar product to attack the rust within the seams and seal them.
(iv) Paint over the whole area under the sills (including the areas still covered with paint + lacquer.) with some type of chip-resistant paint or underseal.
It is years since I’ve tackled anything like this, and I am not up-to-date regarding materials. I would welcome any advice as to whether my general approach makes sense, and specifically:
1) What is the best product to render the remaining rust on the exposed areas inert?
2) What is the best product to apply to the rusted seams?
3) What product(s) should I then apply to the treated exposed surfaces and the surfaces on which there is still paint + lacquer?
4) How should I treat the surfaces covered by paint + lacquer prior to applying those products?
Many thanks.
Many thanks.
