Hi there...
I hope someone is able to help, it's needed urgently......
I have an old Valliant Combi boiler with a British gas EMT2 timer fitted and a room thermostat downstairs.
The room thermostat dated to the 60's so I brought a Honeywell T6360 to replace it. When I took the old one off I found a red,black and earth cable, and a single red on it's own. I was advised..(hmm) to firstly try wiring the thermostat without using the single red. I did this but the boiler wouldn't fire up. I was then advised (hmm) to simply connect the 2 red wires together. This had the desired effect the boiler sprung to life... however when I lowered the thermostat past the switching point the trip switch clicked.
When I turned the power back on I found that the boiler wouldn't fire up again. There is a light on the timer and I can hear the clock mechanism working. I have since put the old thermostat back on and still the boiler wont fire up.
I have now been advised, by someone else!!.. that I dont really need the thermostat as the house is only small and needs to be cranked up to make any difference anyway, so does anyone know first of all how I would I remove the thermostat from the circuit?? Does anyone know how they are wired into this timer..??
The other thing I need to know is is there a fuse in the timer or boiler that will have blown when the power tripped?? There is obviously power getting to the timer as the mech and light is still working, it just doesn't seem to be getting out the other side...
Your help in this is very much appreciated.!!
Dougie
Dougie
