Hi. I am very confused.
I have an unvented hot water storage system.
The system appears to be working ok.
In the airing cupboard there is a Tribune hot water cylinder with a Varem 24 litre vessel on the top of it.
I thought I should check the precharge pressure.
So I turned off the mains water and opened the nearest hot water tap to the cylinder. Then I checked the pressure (with a tyre gauge) at the Schrader valve on top of the Varem unit.
The pressure was zero - which seemed wrong, the label on the Varem said the precharge pressure should be 2.1 bar.
I tried pumping it up but it stayed at zero.
I turned off the hot tap and turned on the mains water.
When everything had settled I checked the pressure again and it was 20psi. No water comes out of the Schrader valve so I guess the diaphragm is ok. And the system works.
I guess I am doing something wrong here...!
And I definitely don't understand what I am seeing...!
Could one of you experts please explain things to me..?
