Hi all, looking for a bit of help or advice.
Last Friday my central heating stopped working. I have a standard vented system with a quite old boiler (Radiation Fuelsaver 9), and feed and expansion tank in the loft.
I managed to get a plumber who's a friend of a friend, (works for BG) to come out. After looking over the system he said that it appears to be the 3 port mid position valve. He set it to the locked open position, and for the past few days we have had a bit of heating, only when the hot water was being called for. (i.e. when the hot cylinder was filling the pump would kick in and boiler would fire up, but once the hot water was satisfied it would then cut out.)
So I set about today to replace the valve. I drained the system, (a bit harder than expected due to a wedged drain cock), but eventually the system was completely drained. I replaced the valve. (it was a like for like replacement) everything went back , all fine. I then untied the ballcock in the header tank and started to refill the system, this seemed to take an age, but eventually it refilled, bled downstairs rads first, then upstairs, shortly after the header tank finished filling.
So far so good!
Switched the power back on to the central heating. Now when the CH only is selected, the pump would fail to kick in. When the HW was selected it would go.
Downstairs I went down and turnt the boiler on, lit the pilot and then on, it fired up.
Now 10-15minutes later, the boiler has gone out. I've tried relighting, I get a pilot when i hold the ignition in, but it will not stay lit.
So a couple of questions really! Why does the pump not kick in for CH only? and is there any suggestions as to why the boiler is not now lighting?
If I need to clarify anything further please ask!
Really hope I can get some help, I would normally let someone more qualified do this type of job, but the earliest we could get someone out was beginning of next week, which was just too long as we have a one year old and the house is gradually getting colder and colder!
Thanks!
So far so good!
Thanks!
