Hi all,
I'm trying to remove the hot tap from a basin and I'm having real problems. The nut which secures it to the basin underneath has siezed and I cannot loosen it. I used a solid steel basin wrench, tried to lever it and eventually broke one of the claws off
I sprayed lots of WD40 onto the joint but still no joy but maybe it will need a long time to fully soak in. I'm now considering heating the nut and using the following replacement tool:
https://www.machinemart.co.uk/shop/...th/pipe-benders-plumbing-tools/brand/monument
Any additional advice on this would be much appreciated !
Many thanks,
Andy.
Many thanks,
Andy.
