I have a couple of switches that i want to replace and had some questions:
first is the bathroom/hall way switch.
i have 2 hallway lights controlled by two switches at either end of the hall. A 1 gang 2 way switch at one end of the hall way.
At the other end of the hall next to the bathroom is 2 gang 2 way switch which controls the hall light on one switch it also controls the bathroom light and bathroom extractor fan off the other switch.
The extractor fan comes on with the bathroom lights and has a fixed live to keep the fan on overun when the bathroom lights get switched off
Ive bought a 2 gang 2 way 10ax switch to replace the switch at the bathroom end of the hall.
I thought i had wired everything up correctly but the bathroom extractor fan comes on and remains on even when the bathroom light is not switched on.
Other than that the hall way lights go on and off fine, as do the bathroom lights. I just cant work out where ive gone wrong with the fixed live for the fan.
Heres a picture showing the old switch on the left hand side and its exising wiring. The arrows indicate where i connected the wires on the new switch shown on the right. doing this causes the bathroom extractor to be permanently on regardless of the bathroom or hall way lights
Can any one help out with this one?
Second is the fused power switch for my combi boiler.
Ive bought a 1 gang switched fcu to replace the old switch.
Heres the old switch
View media item 80473
VS the new one
View media item 80474
All the connections look correct but i noticed that the old switch has a 3 amp fuse in it. ( even though it says on the back has 13/20 amp 250v)
is this safe/correct? The switch has not been touched since i moved in.
The new switch comes with a 13amp fuse so i just want to be sure of what fuse i should be using before i change the switched
VS the new one
