My came down in the morning and my dish washer had packed in!
Symptoms, discharge pump runs for about a second, then beeps. Pause, pumps runs, beeps etc. ad infinitum!
Things I have tried
1. Turn off, wait, turn on - exactly same.
2. Strip discharge pump- no problem found.
3. Pour in jug of water, activate float switch in base – pumps out fine.
4. Strip out all pipe work to recirc pump - no problems found.
5. Bench recirc pum - runs fine.
6. Bench inlet solenoid - works fine.
The LEDs are not showing any fault.
The problem appears to coincide with not replacing the filter properly after cleaning, hence checking all the pipes/pumps for blockages.
How can I fix it if I don't know what's wrong!!!!!!!!!!
Any help greatly appreciated.
Paul
Things I have tried
Paul
