HELP NEEDED TO IDENTIFY UPVC GUTTERING BRACKET
9 Jan 2013
Hertfordshire
Hi all,
I recently been giving my conservatory a bit of a clean-up in preparation for the winter weather, and I noticed a few of my guttering clips had broken (probably from the snow fall last year).
I have searched high and low on the internet to try and find the same type as I currently have installed, but had no luck. I can find a similar type but it is secured with screws, and I need the type that clips in.
I have attached a picture of the type I am looking for, these are the broken ones, and at the rear of the bracket there would normally be a small bit of plastic in the areas circled that would clip into the conservatory. I have drawn in white where the broken bits of plastic would have previously been.
Any help would be greatly appreciated as I am eager to get this sorted before it gets any colder.
Cheers
Thanks for the reply. I have come across the type you found previously and I did order a batch of them, but they actually didn't fit as there is no kink in the bracket to accommodate the shape of the side wall on the guttering. Thanks for the suggestion though.
