The bathroom is in a state after a handyman quit halfway through a job, and I'd be really glad of any advice from this forum. I would like to know how I can make the bath and ledge waterproof and watertight.
Here are my questions:
1. What is the easiest way to fill in the holes on either side of the bath, ideally without having to remove the bath or wooden ledge?
2. When the shower is in use, water leaks out of the base of the hose where it comes out of the taps. Do I just need a washer to fix this, or a new shower hose, or could the problem be with the tap unit itself?
3. The handyman left without painting the wood. He was actually meant to build a tile ledge, but he said the walls were rotten / not solid enough to drill into. I don't even know if he used the right wood for the ledge he did build. What can I now do to salvage it - would it be reasonably resistant if I painted it with several layers of gloss white paint?
View media item 65169 View media item 65170 View media item 65171 View media item 65172
Thanks so much for your help!
