Hi I am currently wiring a block of 80 flats. Part of my job is to install a TV system to the lounge of the flat with a standard TV ariel in the bedroom. I am to use the module type faceplates.
From what I have been told I am to run a dual coax to the lounge for the sky+, then a single coax to the bedroom.
However, with the faceplates there is no physical connection from one cable to the other, the 2 core connect to a sky module with SAT 1 + SAT 2, and then the single cable will connect to a standard ariel socket. I have been told that the sky box will link the two modules out therefore sending a signal to the bedroom. However Im not convinced. Can anybody clear this up? Also is it true that sky multiroom would require a seperate twin cable to each room from the ariel.
Many thanks.
Jamie.
Many thanks.
Jamie.
