HELP! new PVC frames cracked
18 Mar 2005
Liverpool
Someone please help, we have just purchased a new conservatory, and erected it ourselves, all was going well until the double glazed units were fitted, first one of the French doors developed a crack it started in the welded mitre joint, it spread across the door frame out to wards the hinge side, the next morning several of the windows had similar cracks, all the cracks seemed to start in the mitre-- and spread right through the weld or shoot of to the side of the frames, the framework was put up as per instruction , a 4 ft spirit level was used throughout the build,everything is level. what on earth could be causing this to happen ?
Thank you in advance.
Tilly-1
Thanks breezer, we called them today, someone is coming out to look at the conservatory, i just don't want them to try and blame us and wriggle out of of the situation, i hoped someone here might have come across this problem or have an idea as to what the cause could be.
Hi there, the all the dg units are sat on the spacers that came with the conservatory, a friend has suggested that the plastic beads were maybe a touch too big, they were all mitred and in the units when it arrived, we took them out and put them back in the same place, surely they wouldn't expect you to cut them if they have been done on a machine in the factory ?
Thanks Tilly-1
They do expand and I have cut back quite a few of them!
Thank you for your replies, I'm just a bit concerned that they might try to transfer the blame onto us, if it is a installation fault, the so be it, but i wanted to be armed with some facts first, because if their is a chance it's down to manufacturing, then i would like them to correct the problem.
Thank you
Hi again, update on the cracked conservatory.
The guy from Advantage came out today, they are replacing the cracked frames. I asked the chap what has caused the problem, he said "not sure" I asked could it have been the beads fitting too tight, he said "could be" so we are none the wiser, but they have agreed to sort it out.
Thanks for all your help
Lynn
That's great, the beading would bend before damaging the frame!
This can be down to shipping, handling or installation as the windows do not like to be moved or twisted, hence the cracking.
Usually they crack after a few months of installation as the house, conservatory settles down, much like walls in a new house.
They are fairly easy to fix if your in the know.
