I’m a beginner on boilers. Before I drained down the boiler, I had DHW. I had the problem of over-pressure on the central heating reaching 2.5 bar after about 8 mins of switching on, which caused water to flow out of the external flow pipe.
Therefore, I drained down the boiler and recharged the expansion vessel (EV) to 0.8 bar. As there was no water coming out of the EV valve and the 0.8 bar held constant using a foot pump, I assume that the EV was OK. I re-pressurised the boiler to 1.0 bar but noticed that the boiler pressure was dropping. Immediately, went out of the house and saw water flowing out of the external flow pipe. The boiler pressure is now at 0 bar. I think the PRV is damaged which needs replacing. I already know that.
Now I’m not getting any DHW because the burner is not coming on when I turned the hot tap on. The green indicator light for hot water with a “tap” symbol came on on the boiler when the hot tap was on. The pilot gas light is on. I heard clicking in the boiler as I turned the hot tap on.
1. Can someone point out why no DHW?
2. Will I be able to replace the PRV without removing the pump first?
