Help! No heating from a Baxi Solo!
28 Jan 2004
I have a Baxi Solo Wm 40/4 PF gas boiler which has stopped working.
I've had a heating engineer work on it several times now, and it still doesn't work - I'm beginning to think he doesn't know his ar*e from his elbow...
I'm desperate to get this fixed as I have a new baby in the house, and she doesn't like the cold :(
Anyway, the symptoms are that the 3rd light comes on which should indicate that the fan is working and has activated the pressure switch. However in reality, the fan has not started, and therefore there is no ignition or anything.
The heating engineer has replaced the PCB controller board, the fan, the pressure switch and the gas valve! :eek: And still nothing!
It seems that power is getting into the PCB board, but it's not getting to the fan - is there anything else that could be causing this (e.g. the box that the knob is connected to)?
I'd be very grateful for any help anyone can offer!
Thanks,
mr Lew :rolleyes:
are the vacuum pipes clear to the fan pressure switch??
I've just checked them, and the rubber pipes are both clear.
How can I check if the metal pipes (which the rubber ones are attached to) are clear?
Thanks,
Mr Lew
they should be as its a new switch is there power getting to the switch
I'm pretty certain there is - it is one of the things that the heating engineer checked.
it could be the boiler casing seals fauty so the switch is not activating you need to call him out again by the sounds of things either that or something he has supplied is faulty cant really tell you anymore
sorry
Brian
