Hello hope someone can help! Posting on behalf of a friend: who has no hot water or CH in a flat she moved into last week. This is what I know:
- When she moved in there was some hot water!
- The theromstat is turned on fully
- The controller appears to work, i.e. at the prescribed times it turns on the water pump, which makes a normal water pump noise, and fires the boiler
- The boiler (sorry don't know the make/model - will check tonight) pilot is always on, and when the controller program is on, the boiler fires for a while. There is a controller on the front of the boiler, which, when I turn it to the max position fires the boiler
- The hot water pipe from the boiler seems to be warm, though this might be because the boiler casing is warm
- Back to the hot water tank: the temperature sensor on it seems to be turned up to 60 degC; and I tried turning it up further
- There is no hot water in the tank - the tank is stone cold!! Pipes to/from the tank are all stone cold. The pipe around the pump is warm probably because the pump is warm
- It seems to me although the pump is on it doesn't seem to be pumping hot water around the circuit
- The diverter valve has a manual switch to On, nothing seems to change if I manually open the valve
Any idea why hot water isn't getting to the hot water tank??
Should I reset the programmer and start again?
Thanks in advance
Thanks in advance
