Help! No hot water upstairs!
14 Mar 2010
Bristol
My hot water was fine on Saturday, and then Sunday I had boiling hot water downstairs but when I ran the shower, the hot water started hot but faded to cold.
I have a combi boiler and the shower runs from a mixer on the taps. Have checked that the heating is ok and it is, have checked the pressure on the boiler and that's fine too. As I said, I have hot water downstairs and I can get intermitent hot water on the tap in the bathroom too but then that also fades.
Help! :cry:
what combi boiler do you have and also mixer taps can become a problem with combis,as they can send a back feed of cold water to the boiler when they begin to go faulty, either that or if your ht water works with a diaghram it may be slightly perished and need replacing, another solution would be to correct the flow rate of the incoming mains cold supply to the boiler
more than likely the diaphragm wearing out, works downstairs because taps are higher pressure, enough to turn on DHW on boiler. Lower pressure upstairs not enough to move perrished diaphragm.
