I recently started doing gas installations and am qualified. I have a bayonet hose, bayonet socket and a straight wall connector. The problem is the straight wall connector needs the copper pipe(15mm or 1/2") to be soldered into it. The wall connector has a 1/2 female iron socket on the other side for the bayonet socket to screw into it.
Where can i get a straight wall connector with two 1/2" femal sockets. This will let me avoid soldering the copper pipe altogether and just use a compression fitting with a 1/2" male thread.
Please be specific on where to get it as i have being looking lots.
Remember the entire assembly must not protrude more than 35mm so cooker can be pushed back fully. Water tap type fittings are no good here as they stick out too far
Thanks Very Much for any help
Michael
Michael
