Help on re-tiling leaking shower
3 Mar 2013
Essex
Help new to this forum !!
Tiled shower area straight onto plywood (naive!!) leaked. Removed tiles tray to ceiling of shower area. Plywood is on stud wall part of dormer room and sheets go behind rest of tiling in room.so don't really want to remove. Plywood I think is wbp and aligns vertically with upstand on tray and is then silicone sealed.
Read a lot of useful advice on forum (wish I had before starting!!). I want total belt and braces no worries about future leaks and happy to spend bit of time and money to get this peace of mind.
Question is I don't want to come out too much from plywood as will stand out from rest of tiling and onto shower tray. Which is best option:
1) HadieBacke 6mm onto ply then tile (but understand this is not waterproof )
2) Homelux type sheet ..how thick will this result in. If use this how clean does plywood need to be ...some old adhesive difficult to totally remove.
3) Bal tanking
Finally will any water that gets behind tiles come down backer board/homelux/BAL tanking into tray (or will it just be trapped and go horizontally if silicone sealed at bottom??)
Judging by reading previous replies probably no right answer but would appreciate any advice for this situation
