Hello,
Since bathrooms are typically a bit more confined than most other rooms within the home and are frequently wet from shower and bathtub use, there are a few certain decorating needs that must be met. One need that must be addressed when redecorating a bathroom is using the correct kinds of paint. Due to the high-moisture content in bathrooms, this isn't a case where just any can of paint will do.
Bathrooms require a coat of water-based primer before painting the walls with your chosen color. This primer helps seal moisture away from the drywall, which could lead to serious problems with mildew. Some bathroom walls and/or ceilings have become so saturated with mildew that the drywall had to come down and in severe cases some of the studs required replacing.
Follow the coat of moisture-resistant primer with mildew-resistant paint. In some bathrooms that lack proper ventilation, mildew becomes visible on a weekly basis. While mildew-resistant paint won't completely prevent all instances of mildew from occurring, it will prevent it from occurring as often, and it won't allow it to penetrate as deeply, thus preserving the integrity of the actual wall.
if your bathroom has a serious moisture problem, using a paint with a semi-gloss finish (provided it is mildew resistant) will make routine cleaning a much easier process. The smooth finish of the semi-gloss paint wipes up easily with a damp sponge, yet is strong enough not to be marred by many bathroom cleaning products.
thanks!!
_________________
twin size comforter
