Help - penetrating damp issue - suggestions welcome :)
12 Jun 2018
Hi there:
1900 Victorian end of terrace house.
Penetrating damp showing on 1st floor corridor. See internal and external pics (where moss is growing).
This is a small patch. Not sure much can be done to stop a bit of water dropping on this brickwork (i.e. cannot solve the root cause). Instead, can anyone help as to what can be done to help stop this, e.g. masonry cream etc?
Thanks!!!
Ashley
is that a gable wall?
what is the wall like in the loft?
is there a chimney?
does water drip out of any of those pipes?
stand back and take as wide a view as you can please
of all three areas
and from the front and back gardens, the condition of the roof and slipped slates
Hi:
Slightly better pics attached.
Worth noting that the damp patch is above the pipes, but fairly low down on the first floor.
On the questions:
- Yes, gable wall.
- walls in loft are decent condition / dry
- no chimney
- no drips from pipes (damp patch about a foot above pipes)
- roof in very good condition (recent loft conversion)
what’s directly opposite the wall on the the inside of the corridor?
Hi - 90cm wide corridor; staircase to loft. Nothing damp related.
Brickwork needs repointing , close proximity to neighbour severely hampers natural drying process, parapet wall to roof?
it’s possible, if the stairs is directly opposite that heat from downstairs is rising and settling on the wall causing it to condensate.
