I've an Ariston Microsystem boiler (21RFFI). All's been fine for 5 years. The system started to make some ticking noises when running and I thought it was the pump and was going to change it but didn't get round to it. Yesterday the boiler stopped altogether so I've now no heating or hot water. It looked like the pump was leaking, not sure if it really was. When I tried to start the boiler it sounded like it was going to blow up, very hot water was pumped out of the overflow outlet and the boiler system stops. I changed the pump this morning. When I put more water in the system having lost some overnight, the boiler tried to start again. Same problem, very loud banging, very hot water pumps out, boiler switches off again after about 10 seconds. From reading on this forum I am thinking it's a circulation problem, and the boiler restarts when I fill it up but my guess is with no circulation the boiler heats up very quickly (10 seconds or so) then stops with the banging etc. Any other ideas what the problem might be or how I can fix it please? I haven't been able to get hold of a professional to help, first option is Tuesday! (Other info, I think it's a closed system so I've no idea how to put a cleaning fluid in the system) Thanks for any suggestions. Sean
