Hi guys and girls.
I hope someone can help give some opinion on how to make my balcony watertight. This is part of a new extension and although I have been happy with most of the building work this is an area I think may have been constructed wrongly?
Basically the roof itself is fine (it's an epdm rubber roof). The problem seems to be that the cavity tray has been installed too high. I would have assumed the cavity tray would have come out directly above the lead Work?
We called the builder back and his initial fix was to paint the block below the cavity tray with bitumen paint and seal the mortar joint with silicone sealant to help stop water coming through it.
I have since done a water test on it by spraying below the cavity tray onto the bitumen coated blocks. The water is coming through in a few areas.
The lead work seems good and the rubber roof comes up the wall by a couple of inches so I can't see it easily getting in there.
Any ideas guys on what I could reasonable expect the builder to do. He has been back 3 times so far trying to fix it and I want a few suggestions so we can get it right 4th time around.
Ps. Worth noting that we are going to render the house. I guess this may help resolve the issue but would rather it was sorted first so I dont have to rely on the render.
Greg
Greg
