well this is my gem of a boiler,it has worked very well for 18 months.
now i am getting very poor temperature in the hot water,heating is ok.
pcb has been changed 18 months ago due to a total breakdown,also serviced by same guy.
burner pressure on water only starts at 12 mbar after 45 seconds drops to 4mbar.
burner pressure on radiators starts at 12 mbar and maintains at 12 mbar for 24 mins then goes down to 5 mbar.
back to water production,removed ntc/sensor from flow pipe and 12 mbar is maintained but still same warm water,no difference.
flow rate is 9 liters a minute also turned off heating flow isolation valve.
so any ideas.
thanks in advance.
so any ideas.
thanks in advance.
