I own a lovely old house, Cob walls, thatched roof so several hundred years old. Iwas looking at the paintwork on my internal doors and frames and it is so bad I have started to strip it to repaint, however I have discovered that all the door frames are oak so have decided to strip back completely, a rather slow job as cannot use a heat gun as lots of the paint is lead based, but am slowly getting there.
I have however come to a bit of a problem, the hinges of the door are painted over with about 15 coats, I have painstakingly stripped back and found teh screws, and cleaned all round them. BUT I can;t shift them. I have tried the soldering iron trick - no effect, I have tried angle griniding off the very bottom of the hinge to push the pin out - no pin as hinge bottom is solid. now i am at a loss - any suggestions?
Many thanks
Many thanks
