Help please - Potterton Combi 80
25 Aug 2008
London
Hi there
Please can anyone advise me - I don't have a manual for this model of combi boiler and, having lost pressure to the system when replacing a radiator yesterday, I now can't raise the pressure again. (The black dial is on 0).
I guess there's a valve somewhere, but I can't find it!
Any help gratefully received!
Tks, M
you should have something like this somewhere, often below boiler, maybe in a cupboard.
Hi Mick - I can see that hose inside the boiler, but there doesn't appear to be a valve on it - am I looking in the wrong place?
The valve on you're one may just be slot for a flat blade screwdriver.
I turned a valve in the cupboard under the boiler, and water flooded from the former radiator valves!
There's a screw inside the boiler for a flat blade screwdriver - is that the one you're referring to?
Sorry - not a technical person...!
what do you mean by "former radiator valve"
I'm notsurprised there is a slotted screw in the boiler, but I dont know which one you would be refering to.
