- Joined
- 1 Jun 2021
- Messages
- 6
- Reaction score
- 0
- Country
I volunteer for a charity which has just had a storage shed supplied and installed.
The quotation description for the roof felt was 'Heavy Duty 40kg felt'
I took this to mean 4kg/m2 felt ie 40kg for a 10m x 1m roll which I believe is the accepted way of describing felt weight
The felt installed on the day was 2kg/m2 or '20kg' as I would describe it and I protested this as not meeting the spec.
The supplier (shed supplier not a roofing contractor) has said I am wrong and 40kg refers to the total weight of felt on the roof which, as the shed happens to be 6m x 3m, is indeed just over 40kg including the overlaps.
The supplier also quoted us for a 2.5m x 2m shed with the same 'Heavy Duty 40kg felt' although we ultimately only ordered the larger shed. But I am sure this would not have had 8kg/m2 of felt on it.
They have also said the felt is based on the weight of the roll - I am not sure if they mean that as they use 20m rolls the weight is double the weight of a 10m roll.
I'd appeciate any advice on
a) are they right, in which case I will duly apologise of course
b) is there any 'authoritative' document I could cite to argue that '40kg felt' has a generally accepted meaning of 4kg/m2?
c) is this worth arguing or should I advise the charity to roll over and pay to have the work redone?
Thanks for any help ...
