- Joined
- 24 Dec 2015
- Messages
- 4
- Reaction score
- 0
- Country
Christmas eve and the boiler has gone on the blink !!
Started with yesterday morning with a running water noise in the upstairs radiators, so i bleed them and then topped up the pressure on the boiler to 1.3bar
Ran the heating a bit, turned it of re bleed then topped back up to 1.3bar.
Few hours later no hot water from the taps and rads not getting hot.
Went back into the loft and the no pressure at all showing on the gauge.
Filled it back up, but as you fill it you can hear water trickling through the overflow into the drain pipe.
It takes 1.5bar of pressure, turn it back on and it makes a few funny noises but seems ok.
Had a shower, rads getting hot
An hour later no hot water and no pressure at all showing on the boiler gauge.
I have done this fill, use seems ok, an hour later no hot water routine 3 times now.
Any idea whats going on, definitely no leaks in the house anywhere, only thing that seems strange is that some water comes out of the overflow pipe when i fill it but not all as it will get to pressure.
The error code E9 soemtimes come son the boiler but not each time, but my guess is thats just telling me the bliler has tripped as the pressure is to low.
