I could do with some help regarding my hot water and heating, however I do not have the greatest knowledge of plumbing or central heating systems.
The heating in my house never seems to get very hot at all. The upstairs gets to an acceptable standard, however all of the downstairs never even get warm. Also, if the hot water is turned on then absolutely none of the radiators get hot.
I had a look on YouTube at a few videos and it said to balance the radiators by turning the lockshield valve all the way off, and then opening them half a turn. I did this, and the upstairs rads are still hot but the downstairs are just the same. I have bled all of the rads and there is no air in any of them.
Then I had a look at the F & E tank in the loft, and the water in there was completely brown and there was a load of sludge at the bottom. I couldn't find a drain off point on my house so I had to tie up the ballcock with a piece of string and used a jug to empty the tank and cleaned it thoroughly. I then poured a bottle of Sentinel X100 inhibitor into the tank and let it fill back up. Next, I went to one of the cold downstairs rads and drained out roughly 4 litres from the rad and the water from the F&E tank then started to filter through the system, however this still did nothing. This may have been the wrong way of doing it, but not having very good knowledge of central heating systems it was the best I could really do.
The central heating hasn't really worked very well for the past couple of years, but with it only just starting to go cold at night we've only just had to start putting the heating on again, however the boiler has recently started to sometimes flash red with an F appearing on the screen, which probably means there is something wrong with the boiler but I'm unsure if doing something else to the central heating system may cure this without having to get a plumber to have a look at it.
Does anyone have any suggestions?
Many Thanks
Many Thanks
