Hi
The problem is an intermittent hot water problem. Central heating is fine.
Sometimes we get hot water from all the taps and shower, sometimes we don't. Sometimes opening a tap fully for a few mins will result in hot water, sometimes it will just remain cold.
Basically sometimes it works and sometimes it doesn't.
The problem has been getting progressively worse. When the system was installed (4 years ago) everything was fine.
We've recently had the Secondary Heating Exchanger changed. This has not fixed the problem.
The next thing the Corgi registered boilerman has suggested is that it could be a problem with an electric hot water switch in the boiler.
My concern is I don't want to change the entire boiler part by part trying to find the problem, and end up chelling out a fortune. i was wondering if any of you have experince with this boiler and could suggest what the fault may be?
All help greatly appreciated - Thanks!!
