HELP!!! Radiators have stopped working
21 Nov 2006
Hi there,
We have a Potterton PUMA 100 combi boiler
This morning the low system pressure light was on and there was no heating or hot water. I decided to let some mains water into the CH return and that seemed to rectify my problem the Light went out straight away and the hot water became hot and the pressure started to increase. However we were not around to see if the heating got fixed.
This evening although there was hot water available there was only heating in the radiator closest to the boiler.
After locating the prsssure meter on the underside of the boiler the pressure reads
Red on 2.7mbar
Green on 2.6mbar
Please can someone help me to decide what course of action i should take next in torder to try and get the heating working throughout the flat.
Many thanks
Ollie
Bleed your radiators (expel the air)
Pressure is a little high, ignore the red, don't know what the 'green' reading means but the black dial should read between 1 and 2 and be in the green area.
Thanks Baxpoti,
Have already made sure that radiators have been bled both dials on the pssure meter are still just about inside the green area (1-3) as aposed to the red area (3-4) of the dial.
Radiator closest to the boiler fluctates between hot and warm.
a ny more suggestions
Either the pump is stuffed or the wax capsule on the divertor valve. Get someone in..
