The radiator in my bathroom was removed in order to tile behind it.
It was disconnected at the 8mm microbore pipe end of the TRV instead of
the radiator end. After the radiator was reconnected, each time there
was a very fine leak from the pipe end of the TRV. I have now been left
to sort this problem out
I've had experience plumbing with 15mm copper pipe & compression
fittings but not with this thin stuff!! Im looking for suggestions on
how best to connect the 8mm pipe with the 15mm nut of a danfoss TRV
The original pipe had this fitting on the top- can anyone tell me what this
is called and if I should use another one of these or just buy a completely
new TRV or is there a more obvious/better way to connect this pipe???
Any help would be gratefully appreciated!
