help! removing a bristan mono mixer tap
11 Feb 2008
Bristol
ok - i thought this was going to be an easy job. but no.
Rather than the standard threaded rod with brass nut to hold the tap on from underneath, this old tap has what appears to be a black plastic cap, which fits a 12mm socket and has a flat screwdriver slot in the end. The rest of it is appears to be a black plastic sleeve. There's no nut visible further, just under the moon shaped washer.
So how do I get this off?
Please help.
The black plastic part holds the tap to the sink, then there should be the 'moon' shaped plastic and metal washers above the plastic 'nut' between that and the underside of the sink. Correct size socket on the black plastic 'nut' should undo it, if it doesn't then time for plan B.....
here's the offending 'nut' just in case........
I take it that it wont undo? If access is available (i'd suspect not looking at the pic...) then a pair of grips might get it moving. If the nut itself doesnt shift it may unscrew out of the tap body instead.
Failing that then may have to be sink out to get it off....
Ratchet socket and extension bar.
Spray loads of WD40 on it then run the hot tap to get some heat into it.
Then try to tighten it a bit just to 'crack the thread' before you try to undo it.
Until you tried it you can't say you've tried it.
Did you manage to get this off? I have the same plastic sleeve on an IKEA tap and it won't budge.
Alan
