Help removing some pine skirting with easydrive screws to solid wall
30 May 2022
Out skirting is fixed with these screws and I would like to remove some whilst being able to re-use
How can I remove the skirting with out significant damage to skirting or wall (appreciate I will need to fill some of the skirting after).
I have a multi-tool and was thinking of cutting the ends of screws off but maybe an easier way!.
I don't have the the drill bit for screws, but I could but a set if needed.
Thanks both, have ordered one of these ! had always assumed these bolts were going nowhere once in the wall !.
This worked great had them off in 10 mi
forget cutting the heads off the screws are probably harder than oscillating blades just get a security set or the correct bit
this worked great , had them off in 10 minutes with the right drill bit
Agreed, a standard blade would blunt in seconds.
