Hello
In my living room there are 2 ceiling lights. On one side of the room there is a double switch which controls both lights (2 switches, one panel). The left switch controls the left light, the right, the right light.
On the other side of the room, there was a dimmer switch which controlled the left light. You had to turn on the light at the switch and then dim it from across the room.
I have replaced this dimmer with a single 2 way switch.
Now this controls the left light as desired but the left light can now be switched on or off by the double switch
I would now like to replace this double switch with a single one (I have a single 2 way ready to go on the wall), but the wires are confusing me.
Here is a photo of the wires
The left side as seen in the photo is the switch I want to remove. The right side still correctly controls the right ceiling light.
Single light switch:
Can I do this myself, without have to get an electrician in?!
Thank you
Thank you
