- Joined
- 26 Nov 2017
- Messages
- 100
- Reaction score
- 10
- Country
Hi all,
I hope this is the right place for my first post. I'm hopeful someone may be able to assist me.
I've just acquired a Nest 3rd Gen which I'd like to install.
The house was built in 2005 and has an Ideal Icos boiler, Drayton Lifestyle LP722 programmer and what I think is a Drayton RTS1 thermostat (not taken it off to look behind yet).
There appears to be two motorised valves in the airing cupboard near the hot water tank. One is a Drayton ZA5 (C/H) and the other a Danfoss Randall HPA2 (H/W). Since there are two valves, I'm guessing that the system is S plan.
The wiring centre is in the airing cupboard also and is a Drayton Lifestyle box.
My perhaps fuzzy logic tells me that I should be able to shut the power off, remove the wires from the LP722 one at a time, labelling them as I go, then insert them into the Nest Heat Link. I'm just not sure which wires go where and also people seem to be doing it directly from the wiring centre so my approach may well be wrong!
What I'd then like to do, is use the existing thermostat wires to power the Nest Thermostat in the same location as the old stat. The old stat is 230v AC, which doesn't seem to be suitable for the nest so I figure I have two possible options.
a) disconnect the old stat wires at both ends and use T1 and T2 (presumably a 12v supply) in the Nest heat link to power the Nest Stat with the old wires. Not sure how many wires go into the old stat though or what to do with the leftovers to terminate them.
b) use a 12v DC driver (LED light fitting type) at the stat end immediately before the connection to the Nest Stat.
I have very limited electrical and plumbing experience and I dont own a multimeter. Electrics wise, I've wired 16amp sockets, changed an MCB, various light fittings, ceiling roses and sockets but thats about it.
Am I on the right lines with the above? Is there anything I should be on the lookout for?
I'd appreciate any thoughts on the matter. It's cold and the last thing I want to do is not anticipate something and have no heating. Nest installers want £100 (3 quotes, that was middle), which may or may not be excessive and I'll go that route if I'm in any doubt.
Thanks very much in advance.
