Hi folks,
I have a situation in my house where I have two openings leading from my dining room into my kitchen (one at either end). At one opening the dining room floor is level with the kitchen floor and at the other there is about a 30mm drop. The opening with the 30mm drop is a new opening and this is how the difference in the floor height has suddenly come to light.
I really don't want a ramp down to the kitchen at one opening, and absolutely don't want a 30mm step (besides the tripping hazard it would really ruin the symmetry I'm trying to achieve).
I don't think screeding it with a self leveller is an option here either, as I'm not confident that it's just the kitchen floor which isn't level. If I get it wrong the screed is going to flow through my whole house - the missus wouldn't be ammused
In an effort to level the floor of the two rooms ready for tiling here is my plan:
- Put 9mm ply over the whole floor of the two rooms
- Graduate the kitchen floor from one end to the other using plywood and stepping it down from 30mm at one end to 9mm at the other in 3mm increments over the 3.5m span between the two openings (a 3mm step every 500mm or so). I know this still leaves me with a 9mm slope in one opening - but that is manageable - I just don't want a 30mm slope
- When tiling the floor - use the tile adhesive to smooth out the 'stepped' gradient.
A not very good diagram of what I'm trying to acheive...
Can someone please advise me if this is likely to work or if there is a much more practical way that I'm just not thinking of?
Would a 3mm drop every 500mm make a noticeable slope or staircase effect across the floor? Would the tile adhesive then be able to smooth out the stepped effect making it a more gentle slope that you don't really see?
So many questions!... Sorry.
Any help and advice much appreciated. Cheers.
Mike
Mike
