help - Scantronic 9425 problem
21 Dec 2009
Buckinghamshire
Hi everyone,
I have a Scantronic 9425 keypad and the alarm system appears to be working fine. , even though it is apporx 15 years old.
However i decided yesterday when I returned home not to turn the alarm off to see if both the internal and external bells sounded. internal worked, but the external bell box did not sound.
When I do a "bell test" from the keypad the external bell sounds for 5 secs, so i really do not understand why it is not going off when I set the alarm off from one of the PIRs.
Please help!!!!
Thanking you all in advance :D
Make sure you let the entry time finish , Scantronics have 2-ply entry sounders , where the internal sounder triggers ( as a pre-warning) then the external sounder follows later.An easier way to test it is to press the PA button.
There is also a possibility that the bell has a delay programmed , and the PA could be silent ( if the system is monitored).
