This evening I wired in four LED downlights to replace the single 60w light bulb in my bathroom. Before starting I switched off the light and for good measure I switched off the circuit breaker in my consumer unit.
I had wired up nearly all of the lights using 1.5mm2 twin & earth and junction boxes in the traditional fashion and was just stripping the wire on the last light fitting when the RCD tripped and turned all the electric in the house off. I checked all my wiring and it all seemed correct so I turned the RCD back on again. I then put my meter across the bare wires I was working on and the meter read 0.1v (I was expecting zero!). Eventually I plucked up enough courage to finish wiring up the remaining downlight and turned the circuit breaker then light switch on. The lights worked fine and there was no smoke or fire!
So now I'm not suite sure what to do. Firstly, if I did do something wrong with my wiring, could I trip out the RCD even though I had switched off the circuit breaker for the circuit I was working on? Secondly, why have I got 0.1v in my lighting circuit when everything is supposed to be off?!
