Hi there
I'm new to the forum and was hoping someone could offer their help advice.
Our radiators downstairs went cold - we got British gas out and they said there was a blockage in the system (they said pump/boiler/hotwater was fine, so must be a blockage). Anyway, they gave us a quote that was over our budget so we decided to do it ourselves.
Took off the downstairs radiators, flushed out radiators with water until run clear (seemed to clear out loads of sludge from all), cleared pipes before putting radiators back.
Then drained the system down.
Then cleared out sludge (as much as we could by hand first) in the loft and then poured 2ltrs of the x400 into the water tank.
Then filled the system back up.
Then bleed the system.
Then all radiators seemed to be working all downstairs ones came on and worked for a day. Great we thought!
Unfortunately we forgot the heating was on timer so system switched itself off. System did come back on but now only one radiator upstairs is working?!
Not sure whether we should drain the system down or just let it run?
Any advice would be appreciated!
Many thanks
Many thanks
