Help - sheered bleed valve
jf
11 Mar 2004
Anyone got any ideas? There's a ton of air in the radiator and the bleed valve has snapped right off. How can I bleed it? Can I knock the remainder through and get a new one?
Don' knock it, you need to drill it out they are normally brass so drill easily. Be carefull not to drill the threaded part of the radiator.....if you start with a small drill once through you may be able to get a small screwdriver or better still an allen key in and remove the rest of it.
