Hello - purchased the below sliding shower door
http://www.bathstore.com/products/atlas-slider-1100-1992.html
It says it is designed for a range of "1075-1100mm if fitted in a recess (between 2 walls), or 1060-1110mm if fitted with an Atlas side panel".
It will be going in between two walls - and the gap tile to tile is 1060mm - which is out of range (we lost 30mm due to the wall not being straight). What are my options here? Is there any way of cutting it down to size? It cost about £350 and is out of return period!
A detailed sizing of the door is here
http://www.bathstore.com/uploads/files/store/products/1992/p18oeqej871ncs1gl6k0hgtnvt92.pdf
Any help is appreciated!
