Fitted an Warick flange to the top of my hot water cylinder in order to provide a dedicated feed to my shower. up & over the loft and down to the shower, 22mm pipework up until the last 2.5 metres or so which is 15mm.
I did not put an anti gravity loop in as I have not fitted a pump ( and the diagram provided with the flange does not show one). The problem I have been having is that air is getting in the system, I assume that the water is starting to 'fall back down the pipe and into the tank?
When I turn the shower on the water is fine for a minute or so then it stops, if I disconnect the flexible hose from the top of the mixer the water gurgles out for a minute or so, then constant hot water, reconnect the flexible hose and the shower is fine...
I definately have the right outlet of the flange feeding the shower!
Would fitting an anti gravity loop after coming out the tank cure this problem??
