Hi I'm new to this site so please bear with me!
My partner and I have just got a house which needs quite a bit of work on it so have been unable to move in yet as we have 2 children. Stripping the walls and ceilings in the upstairs bedrooms we discovered a damp patch on the ceiling next to the breast wall. There is also a closet on the opposite side of the breast wall which has suddenly shown up a large brownish stain. Upon investigation, the wall under the stain is the consistency of damp sand.
Up in the loft there is a capped off chimney stack. It's soaking wet, the pointing too. Had a roofer out today as first assumption was a leak in the roof but he's ruled this out as the tiles are in good order and the felt on top of the stack is dry. He did however confirm that the stack was very wet and that the rafters it was touching were starting to become wet too. The plywood that the water tank is on is dry and the surrounding pipes do not seem to be leaking as they too are dry. We have a damp specialist coming on Monday with regards to the ground floor where there is damp in the walls and floor.
Surely the damp from the ground floor could not have risen all the way into the roof to the extent that the stack is soaking but yet the breast walls directly beneath on the ground floor and bedroom seem to be dry?
I was just hoping someone had an opinion or possible explanation as I'm stumped. I hope I've explained that clearly enough. I'm sure I'll find out what's going on on Monday but it's annoying me trying to think of an explanation. Thank you.
