[EDIT: I am not doing the work. A qualified electrician is]
I'm doing a complete house refurb including re-wiring. We would like dimmable LEDs downlighters throughout the house.
We've thought of getting - Mains LEDs in all rooms, except the bathrooms where they should be low voltage.
Edit: I need to spec the items that I want the electrician to supply and fit.
I am sure that the builder will try and save costs where he can. I am concerned that they will fit low-end items that will do the job but may fail after a few years. That's why I want to make sure that i ask for good quality items, as this will be a 10 year house at least.
I want decent spec items that aren't top of the range, but are solid and will do a decent job. I've been doing some research and am now a bit lost and confused and hoping for some help!
Dimmer switches - we just want ordinary white plastic. With the face plate as shallow and tight to the wall as possible (is that flush or surface?).
Having had a look I think this might be a decent option: http://www.mkelectric.com/en-gb/Products/WD/logicplus/LED Dimmer/Pages/K1523WHILV.aspx
LED LampsThis is where I am getting really lost.
We want:
- standard round downlighters,
- with a bulb that can swivel,
- white or chromed finish,
- available in cool white AND warm white light.
I've heard that I should get Philips MasterLED downlights. But having had a look around, I've no idea what to get or spec. Phillips seem to offer loads of LED options, some appear to be bulbs that just fit into old halogen units. Others seems much different.
Would be grateful if you could point me in the right direction.
Thanks very much
R
We want:
Thanks very much
R
